help with lower cche bracketry please
hi all
anyone have a diagram of the bracketry for the lower heat exchanger?
i finally have my new one all fanned up and whatnot and i have this funky L-shaped bracket i can't figure out where it goes, but it may not even go on the truck - i have too much crap laying around.
thnaks very much
mike
bad pic but..
you can see the "L" shaped bracket where the rachet and the 2nd down from top arrow arrow is pointing to.
The smaller lengh of the bracket goes into a screw that are pushed into the back of the metal bumper support, and the longer length goes on one of the CCHE bolts as you can see.
The part that mounts on the bumper is just a washer, lock washer and 1/2" (? size) nut, while the bolt is just one of the CCHE bolts with a washer.
HTH
If you need a better pick, lemme know, i'll snap one tomorrow.
Ian Turgeon
Cascading Inspiration
the L shapped braket (2 of them) should be #13, and the front of it bolts to #3. The long side bolts flat where the cche bolts go into the frame
THIS IS WHY I JUST LOVE THE BB.
THANKS TO BOTH OF YOU - VERY VERY MUCH.
oops - caps lock - sorry.
i guess i am short an l brakcet, but that shouldnt be hard to make - *IF* -
would u guys consider these brackets mandatory?
is 1 enough?
gratefully,
mike
Ian Turgeon
they mostly keep your fog lights from bouncing around. Some one with an air/air core may have some extras for you, although they would be easy to make.
sweet - and thanks
my front end is so fubar'd i dont use the fogs anyway, so in it shall go as is with one bracket.
btw, a killer fan app CHEAP is from sac-cycles.com...
i got a yamaha fzr1000 fan, which is a nice little shrouded unit and amazingly powerful - fits perfectly - i used one i had laying round along with a spal, but 2 would be utterly perfect and stupid cheap.
they're pullers - i screwed the yamahopper fan right to the shroud assembly.
i can snap a pic b4 mounting if anyone cares.
thnaks again for the info guys - hope i can help u out sometime
mike
