Hey all:
Got an insurance claims adjuster looking at the truck on Monday and need some advice. I feel I just want to get it driveable and probably will end up parting it out. Please read below and any advice would be appreciated as far as what to do or estimated repair to a driveable state. Right now I've only got prints, no digital pics.
I've got a heavily modded Ty. Black with gray cladding. While parked and unoccupied at the beach a fire started in the engine compartment.
Upon returning I found police and fire truck at the Ty with doors open. Damage in the passenger compartment surprisingly isn't not too bad; Windshield shatered hanging and in pieces, driver-side glass broken and rear window broken, passenger-side dash partially melted and deformed.
External damage:
Morgan's beautiful passenger-side fender & scoop is damaged with paint melted off, 3" cowl fiberglass cowl hood melted to strands, pasenger-side cladding half missing. Front bumper melted, front grill melted
Inside engine compartment damage:
Tranny cooler still intact, radiator damaged, Flexalite dual puller fans melted, Permacool single pusher fan melted, any rubber or plastic melted/damaged, engine harness melted, fuel injector harness melted, battery cable insulation melted, plenty of exposed copper with no insulation intact, BOV damaged, Blitz control unit, K&N filter, headlights and harness
What still looks good: - turbo
- ceramic coated turbo housing
- ceramic coated downpipe & headers
- all cladding EXCEPT front bumber & passenger-side fender cladding
That's it for now and below is everything the truck has in helping u give me some advice.
Engine:
- Stage IV longblock by Rockford Racecraft
- Stock cast iron block, .030 overbore 267 cubic inches Honed, boiled, Cam bearing
- Billet steel main bearing caps, center mains splayed 4-bolt Installed new bearings
- Forged Billet crankshaft (even fire) stock stroke Magnaflux, Polish, new bearings
- Assembly precision balanced Installed same wt. Piston rings
- Fluidamper balancer and pointer
- Eagle H-beam forged connecting rods. Reconditioned with new bearings .001
- TRW forged aluminum pistons (full floating pins) ;Ceramic coated
- Speed-Pro plasma moly rings Replaced
- Federal Mogul severe duty engine bearings (3/4 groove)
- ARP 190,000 psi main and head studs
- Melling HV with welded pickup
- High performance roller camshaft (.488/.510 lift, 206/212 duration)
- Comp Cams roller tipped rocker arms (1.6:1 ratio)
- Hardened pushrods
- Speed pro roller lifters Replaced with GM original
- Fully prepped L-35 vortec heads with mild porting Full valve job, deck squared / ceramic coated
- True roller timing chain Cloyes true roller
- Block clearanced for rods
- CSR Race starter
- New valve springs
- Premium OEM and felpro gaskets Felpro Graphite cometic
- SFI HD flywheel
- GM ECM
- Nolan's Custom chip
- 50 lbs/hr injectors
- ATR 62 series turbo and wastegate
- Turbo housing ceramic coated
- 3” ATR stainless exhaust
- ATR double pumper; 2 fuel pumps 2nd pump kicks in around 12psi boost.
- Permacool Prm-19010 10" fan; pusher fan
- Flexalite Dual 12” Fan; FLX220
- B&M Supercooler Transmission Cooler; 70274
Parts done/changed during rebuild which I picked up 2 weeks ago:
Rebuild
Valves
Crankshaft adapter
Engine Wiring harness
ECM computer
Spring & locks
Ceramic coating
Cam
Lifters
AC Relay
Fuel pump relay
Bosch fan relay
New Chip
Ignition coil
Wiring harness for injectors
Wastegate solenoid
EGR valve
Solenoid
Delco 3 wire o2 sensor
Misc.:
- Blitz SBC-id electronic boost controller
- Lowered
- Battery in right wheelwell
- Boost, trans temp, and fuel pressure gauges in A-pillar pod
- Cowl Induction Hood
- Newer transfer case
- ATR 3” exhaust
- ATR stainless headers; Jet Hot Coated
- ATR externally wastegated downpipe; Jet Hot coated
- Driveshaft loop
- Baer disk brakes (front and rear)
-Chrome ZR-1 wheels Front: 17x9 front 38mm offset
Bfgoodrich G-force Kd tire; 275/40/17
Rear; 17x11 56mm offset
Bfgoodrich G-force Kd tire; 315/35/17
- Recent paint Black over gloss gray cladding
- HID headlights
- 160 AMP alternator
- McCoy Air-to-Air intercooler
- Throttle body air foil
- Oil: AMSOIL synthetic oil
- Tranny oil: Synthetic
- Radiator fluid; Distilled water and Redline additive
Transmission
- Stage 2 transmission By CK Performance
- Billet “9/11” high stall torque converter
- B&M torque converter lockup controller
- New reverse drum, sun shell, 3-4 ring clutch
- "Corvette" HD accumulator piston
- HD adjustable pressure valve and seat
- Replaced sprag bands, clutches, drum, and mechanical diode with severe duty components
Thank you very much to all who've responded and offered advice.
External damage:
Engine:
- Hardened pushrods
- CSR Race starter
- New valve springs
- SFI HD flywheel
- GM ECM
Rebuild
Valves
Crankshaft adapter
ECM computer
Spring & locks
Ceramic coating
Cam
Lifters
AC Relay
Fuel pump relay
Bosch fan relay
New Chip
Ignition coil
Wastegate solenoid
EGR valve
Solenoid
Misc.:
- Lowered
- ATR 3” exhaust
- Driveshaft loop
- HID headlights
Transmission
