4C FED
Absolutum Dominium
Re: trying to start .... please could someone help?
See the 2 & the 6 in your pic?
What about the rest of the harness connectors? Do you have everything hooked up? TPS, IAC, CTS, IAT, MAP?
Nevermind, I'm thinking of my FAST harness which has different colors. If you look at the injector connector you'll see a number that corresponds to the correct cyclinder. From what I can see it looks correct.Pass side fuel injectors:
Dvr side from above:
I honestly think the timing is set correctly so I am wondering what else the issue could be?
Spark = ok
Timing = ok
I am thinking something is up with the injectors but I'm not sure what it could be? Any suggestions?
I could take off the rail and bypass the fuel pump and just see if all the injectors fire properly? Is there another way of doing this?
What else am I missing?
