Re: trying to start .... please could someone help?
OK,
a few things happened today. First off, the dist is in perfectly. The lash was off and I have adjusted it and the engine now runs and idles almost perfectly apart from two things.
The engine will idle very very well without the FP relay connected. It seems to be running off the residual pressure in the rail. If I attempt to connect the fp relay then it dies almost immediately. I am worried that the guys that put in the immobiliser may have done something funky to it.
I thought it was rich so backed off the fuel pressure to 30 then to 20 psi and that did nothing.
That said, when I jumer the relay the fuel pump runs really well?
The next issue is potentially way more serious. I am getting no oil flowing through the rockers into the valve covers. Everything I have been told suggests that they should be covered in oil and it should be flowing a lot of oil into these areas.
The insides of the covers are bone dry. I know the pump is working as the oil feed to the turb spews out oil from the remote oil filter so that isn't the problem.
How can the rockers and valves be getting denied oil like this?
I thought I was going to have to oull the engine, then thought I didn't need to and now it look like I might be back to square one again.
Damn this truck is a rollercoaster of emotion.
OK,
