Slyclone
Well-known member
Re: Typhoon Project
Quick Update, Dropped the transfer case and replaced it with a new back up one I had in storage. I cleaned up the threads on my awd adapter/trans mount. Turned out things were not as bad as I thought. Started to mock up my 3 inch muffler. did some brake work when I was there doing new rear cylinders and draining any old fluid. And lastly was able to break down the top intake and remove the injectors and work on the fuel rail in prep for the stock set of injectors soon to arrive. Another board member hooked me up with a stock chip so... once I get the injectors (stock) I can plug them in.. see how the truck responds with the ATR chip and if anything still is not right I have the stock chip to plug in and see if that works. Plan is to use the stock chip. But I would like to know if the truck responds to the injectors as I think the truck had the wrong 40# which I just removed. Ordered some more stuff for it so things should pick up by the weekend.
