Ty1679 modified even more!
QUICK STORM
B.A.M.F. BMW Tech
My build sheet:
TURBO/INTAKE:
-PTE67DualBB
-custom coolant lines for turbo
-PTE HD actuator (18-30psi)
-Custom FMIC
-BBK 58mm Throttle Body
-3 Bar MAP
-HKS SSQV blow off valve w/ purple insert
ENGINE: RPM Complete Long Block
-P&P Vortec heads 2.05/1.60
-P&P lower intake for vortecs
-P&P upper intake
-415 comp cam
-Cometics Headgaskets
-Pro Gram 4 bolt billet caps
-.040 over
-Nitrided Stock Crankshaft
-.040 SRP pistons
-JE piston rings
-Eagle H-beam rods
-ARP main stud kit
-ARP head stud kit
-RPM detailed block
-freeze plugs installed, etc.
-RPM fully balanced, assembled, etc
-Comp cams 1.5 roller rockers
-Comp cams roller lifters
-Cloyes double roller timing chain
-Melling High Output Oil Pump
-SFI dampner
-SFI flexplate
-Eldebrock Hi-Flow Aluminum Water Pump
-A/C delete pulley & belt kit
-JS Frame pads
-Moroso Solid Motor Mounts
-160 thermostat
-Volvo eFan Kit
-DCC fan controller
-Aluminum Valve covers w/breathers
TRANSMISSION/TRANSFERCASE/FRONT & REAR DIFFERENTIALS:
-2800 stall converter
-5000 rpm Governor
-Cast deep alum trans pan
-B&M trans cooler
-HD front propshaft
*Saving for the George Blake/JSM 4L80E conversion*
-2001 4L80e
EXHAUST:
-Ported and Extrude Honed Stock Exhaust Manifolds
-PTE 3in Downpipe
-McCord power plate dump
-Borla 3in SS catback exhaust
FUELING:
-KB AFPR
-75# injectors
-Walbro 255
-Racetronix fuel pump kit
-Bosch Aux. fuel pump
COMPUTER/CHIP:
-Stock ECM w/ upgraded inj. drivers
-phil long 75# chip
-soon to have code 59, already have the equipment to burn chips
-HKS Turbo Timer
-Blitz SBCiD electronic boost controller
IGNITION/BATTERY/lLIGHTING:
-NGK spark plugs
-MSD distributer
-MSD 6AL
-Crane Coil
-MSD 8.5mm wires
-Rear mounted in cab battery box w/optima red top
-140A upgrade
-H4 headlamp conversion
-Clear bumper parking lamps
HEATING/AC
-Non A/C heater box
-A/C delete
BRAKES/WHEELS/TIRES/STEERING/SUSPENSION
-ABS delete
-Borgenson Steering Shaft
-ZQ8 steering box
-Drive shaft loops
-2.5 lowering blocks, soon to have belltech springs
-ZR1s on drag radials
QUICK STORM
B.A.M.F. BMW Tech
Re: Ty1679 modified even more!
cleaned the list up so its more understanable
keep in mind the truck is broken and i'm just stock piling parts. hopefully i will have it running by the summer
QUICK STORM
B.A.M.F. BMW Tech
new motor showed up at my dads shop today. now i just gotta get time off of work to get my truck towed to his shop and put in the motor along with my other goodies!
