Drag SGT
All Throttle No Bottle
Alright, there's a lot of options on the table right now for which way to go on the truck. We know we want it to be carburated/v8, but we're having a hard time picking which engine and whether or not to lower the compression and go boosted.
These are our main competitors. If you have another entry, feel more than free to post up a pic and say why.
Competitor #1:
454 600hp 575 Ft. Lbs. Motown Cast Iron Block Motown Lite 220 Aluminum Heads $12,295.00
Specs:
Block: World Motown cast iron billet caps
Crankshaft: Eagle 4340 crankshaft
Balancer: ATI SFI
Connecting Rods: Eagle H-beam 4340
Pistons: Mahle coated/Manley
Piston Rings: Total Seal
Compression: 10.5:1
Bore/Stroke: 454 c.i.d. = 4.250" x 4.000"
Bearings: Clevite H-bearings
Camshaft: Hardcore solid roller lifter
Timing Chain: Hardcore double roller
Cylinder Heads: World Motown 220 (aluminum)
Valves: Manley Severe Duty® (2.080" intake, 1.600" exhaust)
Valve Springs: Hardcore
Retainers: Manley
Valve Locks: Manley
Valve Seals: Hardcore
Rocker Arm Studs: Manley
Pushrods: Hardcore 4340 1 pc.
Pushrod Guide Plates: Hardcore
Rocker Arms: Scorpion aluminum rollers
Oil Pan: Moroso
Oil Pump: Melling/Federal Mogul
Assembly Components: Stainless hardware
Intake Manifold: Motown single plane
Carburetor: Hardcore 1050 cfm (4500 type)
Distributor: MSD
Fuel: Pump gas
Competitor #2:
427 625hp 575 Ft. Lbs. Motown Aluminum Block Aluminum Heads $11,895.00
Specs:
Block: World Motown cast iron billet mains, Motown Lite aluminum, billet mains
Balancer: ATI Super Damper
Pistons: Mahle
Compression: 13.75:1
Bore/Stroke: 427 c.i.d. = 4.125" x 4.000"
Cylinder Heads: World Motown (iron & alum.)
Valves: Manley Severe Duty (2.080" intake, 1.600" exhaust)
Oil Pan: Moroso
Distributor: MSD
Fuel: Race
Oil Pan: Moroso
Competitor #3:
Any motor you can think of based off of the LS2 carburated version
This is basically the free-for-all category. Go wild. :myclone:
Also. Tell me whether you'd go boosted or not and why. Thanks! The more options I'm able to see right now, the less dissapointed I'll be if I find one down the road that I like.
Competitor #1:
Specs:
Balancer: ATI SFI
Compression: 10.5:1
Retainers: Manley
Valve Locks: Manley
Oil Pan: Moroso
Distributor: MSD
Fuel: Pump gas
Competitor #2:
Specs:
Pistons: Mahle
Oil Pan: Moroso
Distributor: MSD
Fuel: Race
Oil Pan: Moroso
Competitor #3:
