turbodig
Re: High Speed vibration issue
Not sure what you've tried, but I'd do a few things.
1) Fresh wheel balance by someone who really does good work.
2) Pull front propshaft and test
3) Add shims under the rear trans mount, see if it makes it better or worse.
It might be that the trans mount needs to be shorter.
They make level adapters to check that your T-case output angle is the same as the pinion angle. You can also makeshift an angle measurement, but it's a lot tougher to get accuracy.
You might have a side-side misalignment as well, although that would imply a bend/tweak
someplace. (ie, previous accident damage)
ty166 said:thats why its been in storage for over two years , i figure i'll try a couple more thing and if that doesnt do it " BYE BYE NOW" , seriously its unsafe bad , you'd think something this bad would be easy to spot. im thinking its gotta be a tire/rim problem. not a whole lot left on my truck that hasnt been checked or replaced.
