my small project
SY2455
70's Veteran
Re: my small project
:rotf: I see you use the cup holders for the same thing I do. :rotf: 2 more and you can buy the Sunday paper.
gjp
another post whore
LOL...Its not like a cup can fit there. I think that change was there when I bought the truck. I also found a checkbook (previous owners) in the center storage area. I think this was the first time I was in there since I bought the truck.
George Blake
DONATING MEMBER
Something I would recommend is connecting your laptop wire harness into the existing harness and covering the end of the plug. I just noticed. You've got a serial plug on the underside of the dash already. If you did the harness plug for the TCI that would look good doing it right next to that one. This way you don't have to fish the harness out to plug it in if you ever wanna change shift points. Try doing the "eco/perf" wire hooked up to a switch that goes to ground and do some experimenting. You won't hurt it:tup:
gjp
another post whore
Thanks george. I have a switch I was going to use for the converter lockup but now it will go to the black wire. install was not to bad. I Will run your program till I feel I am ready to play with it. looking for a mid may track date.
Oh....and a I added one final mod today.
gjp
another post whore
wantingasy said:
Looks good. I thought you got new mirrors?!? Haven't put them on yet?
Screws came in a few weeks ago. Just been lazy on the install.
gjp
another post whore
done for today. need a few bolts, fittings turbo, DP, A2A and its done.
Powered up the volvo fan today. WOW all I can say is it blows
The best part is NO TV CABLE
Found a few before pics,
gjp
another post whore
Thinking today at work about my truck and what I have done in the year I have had it. And all the friends and help I recieved. I want to say Thank you to Roy, Chris, George, Mike, Jeff, Brandon and all the others for your help. Also would like to say RPM, JS, and Prime gears for the cool parts. These vendors Rock!
I made a list.
LS1 Brakes
L35 heads 2.02 1.60 ported with SS valves
Ported intakes
3"SS exhaust ATR
RPM stage 2 turbo
Typhoon side mirrors
Exhaust Ceramic coated
PLX 250 WBO2
Razor Alky
4L80E Built by Prime gears
TCI trans computer
Custom Gilbert
Custom rear shaft
JS converson Kit
2800 Bille stall
RPM A2A
B&M trans cooler
Silicone vac. lines
Volvo fan
fan mounting kit
Dc fan controler
52mm TB & air foil
ABS delete
RPM brake booster valve& hose
Braided fuel line
braided trans lines RPM
3 guage pillar
Greedy controler and boost guage
Dampner
billet pointer
edelbrock water pump
polished timming cover
edelbrock double roller chain
130A alt
Powder coated brackets Alt/AC
PS pump
Phill long 50# chip
3 bar map
50# injectors
10" kicker box
150watt amp
Datamaster
Heater core
MSD coil
Distributor
taylor wires
RPM valve covers
Front axles
Solid motor mounts
Zq8 box
Steering shaft
Roller rockers
pushrods
Oil pump
EGR delete
Phil smog chip :roll:
Thats all I can think of so far
Thanks for everyones help
Black Knight
I Glow Therefore I am
Wow, Gary you're getting really close bud :tup:
Can't wait to see you fire it up, next time I'm in town I'll swing by for sure and go for a ride :)
ty166
that sure is one clean looking truck under that hood. i guess thats what it looks like when you replace EVERYTHING ... that list sure did grow in length from the first post in the thread... :rotf:
gjp
another post whore
This time we can hit up a Giants or A's game. I owe you. and I promise not to beat up anyone or yell at them this time ;)
Roy, you comming down if tom has a party again?
Yeah, the list did grow a bit. I am sure I even forgot some stuff.
live1053rulz
Nor Cal SyTy
woowee man, you're gonna be done in no time. i can't believe i still haven't found the time to cruise by.
gjp
another post whore
Anytime steven. I live right accross from Independence HS. Anyone is welcome to swing by and BS anytime. I still want to see your TY too. and your 69.
Black Knight
Actually I'd be disappointed if you didn't get us into a fight :rotf:
Have you heard if he's having one this year, or when? I haven't talked to him in a long time so I don't know what his thoughts are. More then likely if he has a party I'll try and be there, last year was a blast! :tup:
gjp
another post whore
Watch out. I carry a weapon now. Insulin syringes. :rant: I am having complications right now. I hope to finish my truck next weekend. This week I have been to the hospital 2 times already and its only wednesday.
wantingasy
Damn, sucks to hear. Definitely feel better first before you continue to work on the truck....and stress out more :tup: It's coming along good and I hope you start feeling better.
gjp
another post whore
Life happends....
Yes, I do have some skills.....Now I have to find a coating place, Cheap
