Re: my small project
Looks good :tup:
gjp said:just needing vac lines and drivers plug wires and a few straps.
Looks good :tup:
wantingasy said:Keep a fire extinguisher reallllllllllll close :tup: Just in case. Other then that I would double check all the important stuff that could easily blow off/leak. (I.E.- Radiator hoses, fuel rails, injectors, etc.) Make sure there's nothing in the way of the front pulley system too. I'm sure you already know this stuff :tup: FIRE HER UP!!!
everything is new. replaced both pulleys. Could be the fact everything is new. Also remembered the tan wire is unpluged so i can check the timming. Could be why the engine is running crapy. I will start it again tomorow.4C FED said:Tesioner or idler pulley?
Remove the belt & turn everything by hand to see if anything feels funny or squeaks.
Start it without the belt to see if squeak is still present.
I was pushing the stock injectors with the stock engine and the stage 1 turbo. going to a 3 bar and chip it made sense to go with bigger injectors. The 50# injectors were priced good from someone on this site. with the new heads and larger turbo I will need the larger injectors more.ViciousV6 said:gjp,
Was reading through your post. After seing all the work you have done to the truck sweet. Just a question are you running bigger injectors because you will be needing them for the increase in air flow. A larger injector is being safe, if they are too small it will be too late.
Some helpful advise.
Ralph
ViciousV6
