my small project
WyoSyclone
Re: my small project
Keep up the good work Gary.... you're an inspiration to the rest of dealing with mechanical (and health) issues! :tup:
gjp
another post whore
my last part came back in today. Thanks Mike Lee. now its just time. and luck
gjp
another post whore
After bitching, yelling, and throwing stuff I think I got the hard stuff done. The turbo was a bigger bitch then I was expecting. Got it in. Lower pipe wrapped. Not sure if I will wrap the upper pipes yet. Everything but the vac lines, DP, lower IC pipe, plug wires and inner fenders are in.
wantingasy
It's so clean under there :tup: I wouldn't wrap the upper pipe, it looks so good the way it is :rotf: Man, you're almost ready to fire it up and be bulletproof forever..........hopefully
Z SKI
looks great, i will be going through about the same project real soon. This has been an inspiration to me and i feel better about doing it all myself soon. Big thumbs up or :tup:
gjp
another post whore
worked on it again this weekend. Trans is done..Again. Whole bottom of truck is done :D No more crawling under it..For now at least. After Sean left today I was able to finish everything but the drivers fender and vac lines. No pics for now till I get my old computer to work better. My laptop is in the shop. I hope to start it up sometime this week.
Flyin Ryan
hated cuz he drives fords
Unwrapped upper ic pipe looks nicer in my opinion but unless you have meth injection wrapping it may help alot with keeping your intake temps lower.
gjp
another post whore
I am spraying meth. My temps at night would drop in the 70's on a run. I wraped the turbo to IC pipe.
Last pic before my IC went on. I love a clean engine. and yes I put a bolt in that bracket hole.
autoaddictions
You need to get the March Performance pully set. Polished and cleared. Clean engine is sweet!!!!!!
TYPHOOL7
Post Hawk
Blew a head gasket on the Ty last week so I decided to tear her apart. At first (on page 1) I was like cool someone is doing exactly what I am; untill I saw how far you went. Nice job, your setup looks amazing. I went with the cheap version of your project, painted some things on the truck :) and may have left that bolt out on the bottom bracket (jk). I didnt do anything beyond the top end and a lot of cleaning everywhere else; I am jealous.. pics soon of the finished situation.
gjp
another post whore
Thanks..It started out small at one point. today I painted and installed the inner fenders and CC parts. Looks empty with no ABS on the drivers side. Just have the Vac lines and I am done :D Hope to have pics tomorow. Just got a memory card reader for my POS computer because my laptop is in the shop. I wish the geek squad would hurry up with it.
TYPHOOL7
Post Hawk
I noticed you had some problems with your rockers. I went with l35s and when I put them back together I was unsure about the method of install. Stock heads have the rocker posts pressed in and on the l35 they are screw type. I bought the heads assembled and only when putting them back did I notice(they werent there). Long story short they are all tight so tightened them up to 20lbs or basically just under a turn past 0 and they are all seemingly ok although I have not run the truck yet. What was your reason for using different rockers? (which ones?) and you didnt have to get a new set of pushrods did you? They appear to be the same length.
gjp
another post whore
my heads came complete with posts,valves and springs. The posts were the wrong size. I figured while I was getting the new posts i would get new rockers and hardened pushrods. Pushrods looked to e the same length but i never checked them. Reason for the new rockers.....I just figured why not. I never like stock rockers so i got the cheap stamped rollers with the 1.52 ratio. i got most my stuff from RPM.
gjp
another post whore
just needing vac lines and drivers plug wires and a few straps.
