Re: Quinnster's Syclone 2208 Rebuild
What paint did you use on the manifolds and how's it holding up? You had it running recently? Looks great.
I'm about to undertake a similar endeavour and want to tidy up my engine and frame. What did you do in terms of prep and paint exactly?
Finally, I really like your wheels. What are they?
Thanks!
Sorry for not responding earlier. This was my first engine and vehicle restoration so I don't believe what I used was the best, but I'll share what I did do and what I think I should have done differently.
On the Exhaust manifolds I asked the company what paint they used on the Turbine side of the turbo so all of my exhaust colors would match which they did, but It seemed like 20% of it burned off in the first few miles. If I were to do it again It would be better to have it baked on there, or ceramic coated professionally for longevity, but it still looks pretty good how I did it, just not perfect.
Then for the frame I used the spray paint version of truck bed coating. It also worked pretty good, but If I were to do it again I would probably use POR-15 since everyone has such good luck with it and helps stop rust. But also at the same time as long as the frame is painted black it looks better!
Before
After
And here's the stuff I used to paint the engine. I used the low gloss black for the oil pan, the silver for the Aluminum parts and gloss black for the rest. and all of that paint is holding up perfect!
Then the wheels I like and don't at the same time. They are made by OE Wheels and are 17" Z06 replicas. What I do like about them is the look although I may power coat them black now, but what I don't like is that I need to buy a wheel spacer to make the offset right, and I used to have a 12" wide tread width in the rear with my last set up, and when I went with these narrower wheels I sacrificed how well the truck used to do in the corners, but my old wheels were ugly on the truck!
As far as after it getting stolen I haven't got to work on it as much as I would have liked to, but I have been taking my time and getting every thing 100% buttoned up before I start driving it again. I have been thinking of getting all the parts together and once I got them all taking a week of vacation days from work and get her done!
This is where she sits currently.
I decided it would be a good idea to take of the majority of the interior and hide my alarm, relocate my battery, run my stereo, WBO2 wires, Alky wires, ect and sound dampen the interior while I'm at it.
Good luck on your project, I hope it goes well and gets done with less hangups than mine did.:lol:
Anyways I hope this helps. Good Luck!:tup:
