pearl91chevy
Took off from a stop sign normal speed, heard a grind and before I could even let off the truck lost drive and grinded to a stop which sounded horrible. I could not get it to roll in any gear and had to get it towed home. Still runs fine, no matter what gear the truck will not move. I can see a little rpm drop when I put it in reverse, but still no movement out of the truck. There is no holes in the trans and no fluid on the ground. Driveshaft is still connected. We got it to roll in neutral with 4 people, would stay locked in park and not move..
Soooo what happened here? Will probly start pulling the trans tomorow or the weekend, but curious about what actually happened. I'm determined to make it back to the track before seasons over. I do not plan on building a 80e trans since I don't plan running faster then high 11s. Should I rebuild this trans, or find a replacement?
