Re: 5.3/4L80E Single Turbo Typhoon Build
Eviltwin and I were able to get a bunch of stuff taken care of this weekend. We removed the tranny crossmember and rubber mount, sold the crossmember, made our own, and modified a poly mount for use on our application. The crossmember is a very straightforward design, so it didnt take too much fuss to make our own.
We were having clearance issues with the fat dash 10 fittings that come out of the oil pan and the diff, so we are in the process of rotating the diff a bit as well as beveling the back edge of the flange that comes off of the diff. This should give us just enough clearance. (annoying annoying oil pan).
Our fans came in so we mounted them up to the radiator and tranny cooler, made a brake line that we were missing, mounted the oil filter, mounted the fuel pressure regulator to the frame rail, ran battery cables, and even got the driver side inner-fender trimmed and installed. Took a few pics of the progress. Enjoy!
The transmission crossmember welded up:
Painted and ready to be installed:
Here it is installed with the modified poly mount. You can also see where we mounted the fuel pressure regulator on the frame rail:
The C6Z06 brakes are just too damn sexy not to post a pic. You can see our aluminum intake tube and BOV installed, and not to mention Eviltwin's Syclone in the background, being neglected while we work on the typhoon. This was just before the inner-fender went in. Forgot to get a pic after it was in, but oh well:
We only had to trim a little piece off the inner-fender to get it to fit perfectly. The other side isnt going to be nearly as easy...
