You got all them guys in Louisville that can help you out and your close to Chigago.Don't know about that. There's going to be a ton of little shit to finish up once it's back from paint. It might be close.
Frame looks great!
Pulling them once it gets to the painters. There's a small amount of rust on the drivers door and tailgate. The rust on the gate has seemed to have grown over the last couple years. Hopefully won't need to replace it all together.painting it with door and gate on? or pulling them at painters?
Yup. Once it gets to the body shop, they'll be pulling the body back off the frame so I can bring the frame back here and install the motor and trans, finish buttoning up the suspension, brakes, brake and fuel lines.JJ, coming along nicely. But don't forget to change those lower ball joints and mount them from the bottom!
No clue what it is.Truck looks like it's coming along nicely.
Is that a Lincoln Zepher kit?
Nick
Naw. Just gonna get the reproduction ones that stickerbomb is working on.J.J. are you going to have them cover and tape off your door jamb sticker?
The body is coming off the frame this week so I can finish up a few things and so they can paint the underside.Boy it sure looks good. Make sure those guys don't get any overspray on that frame.....I'd go crazy if it were mine.:rant:
I thought about that, but hadnt brought Iit up with them yet. Plan on making sure they do that though.Just a fyi, the door wiring can be pulled into the body, and pull the strikers other wise they will chip first time you shut the door
