Re: Rebuilding Ty #284
well, i managed to get the 20G balanced and it was way off, gey said whoever balanced it before must have only doen the compressor, because the compressor was close but the exhaust was horrible. I noticed that it was also marked and he wanted it to be put back together in a specific way, as opposed to last time when he said it didn;t matter.
Anyway he also looked at my center section and said that the reason that it had blow apart was because of a ring that had been ground into the housing from the exhaust side. He said they really didnt sell new ones and that I would have to find one (he did have one but it was 950) I asked him if a 17c center woudl work and he said he thought it would, other than the 20G was a superback and the 17C wasn't. lucky for me I knew what he was talking about. The gouge that had been worn into the CS had also been worn into the shaft, he cleaned it up and gave it back to me, saying he was pretty sure it would work.
I went to put it back together using the 17c and saw that that housing was good, although dirty. I cleaned it and began assembly. I couldn't get the exhaust side snap ring to seat right, and bent it taking it off a few times. When he cleaned it off he made a bit of a lip where that ring is supposed to sit and and ended up having to file it back out (carefully) but I ruined the ring so I was ****ed.
I asked warmpancakes if he had an extra turbo laying around and he didn;t but he had just sold one to neil. I assumed neil had a bad stock turbo and gave him a call. sure enough he did, and he offered to let me use it for parts. I got it home and saw that the trust play was good, and that the oil seal had no wear on it. I put it on my turbo, and assembled it. The only other issue I ran into was that the regular back thrust bearing was longer, and I had to re-use the original. I torqued it down with some lok-tight and checked it for play. no thrust, a tiny bit side to side.
I won't have time to put it on until saturday. hopefully I can make it to the met, should only take me and my buddy an hour to get it back on and running, and 15 minutes to do an oil changed.
