BMFB
Not to scale
Re: Rebuilding Ty #284
well, its getting better all of the time...
I got the trans cooler mounted, its the 16 pass derale cooler with a fan. I mounted it in front of the back axle on the driver side. Running the lines was kind of a pain, I did hardline from the trans, down the pass. side frame rail, up across the exhaust and driveshaft and then over to the cooler. I mounted the switch behind my alky control box in that black plastic piece that covers the lower heat ducts. just driving down the highway with it OFF it keeps the trans 20*F cooler. Unfortunately the first switch I choose could not handle the amps and melted (old mystery switch I found) so I had to replace it today with a better one I bought.
I took it to the woodward cruise last night and ended up running a built srt-4 neon. we talked for awhile about our cars, he said his "ran 12.5's on slicks before he had it tuned" and he refused to do a dig on grounds he would be destroyed, so the best I could get out of him was a 30 roll, as that was the slowest he could go without traction issues. First run went bad, as he spooled much faster than me, the second run he let me have the punch and we hung side by side until about 110 when I let off. I was happy for only running 16psi.
On that note, I am still investigating what to do about my gate issue. I need to either buy a forge, or modify what I have, either by means of cutting the stock actuator open (I have a spare) or adding a spring. I haven't decided what to do.
Still have a small leak in the trans lines...need to solve that. also replaced my boost gauge light that went out on my way home last night.
my tcc is acting up, I think its a solenoid. I am going to play with it and them most likely end up replacing it.
